jamesglanza Posted May 10, 2012 Posted May 10, 2012 Does any body know where to get tight fitting spacers from? 4x100 hub hole diameter around 56mm and 3mm thick? its only so i can finally fit the center caps on my rota grids.If any body else has had this problem will 3mm spacers be enough?Cheers. Quote
A L 3 X Posted May 10, 2012 Posted May 10, 2012 I also had this problem, 5mm spacers worked but caused rubbing issues soI modified the center caps bringing them out away from theHub nut. I can show pics of how if u like? Quote
Liam_D Posted May 11, 2012 Posted May 11, 2012 My bro had this problem with his Rota Grids he just bought some 5mm ones for Halfords and it solved the issue. Quote
jamesglanza Posted May 11, 2012 Author Posted May 11, 2012 Pics would be a good help thanks.Wanted some tighter fitting spacers than the cheap halfords ones bud as have used them in the past and they are softer than chocolate.Thanks. Quote
A L 3 X Posted May 11, 2012 Posted May 11, 2012 Will do when I get to a pc mate, or if u wanna pm me your number I can try send pics and explain it on thereAll it is is a bit of plastic welding then some tiger seal Quote
