Chand Posted May 17, 2012 Posted May 17, 2012 Hi This has probably been asked before But anyways hopefully someone can help me out Firstly when I'm driving and cars up to temp (oil and water etc) And I put my foot down once It gets to near 6000 rpm It like sounds like its restricting it self If that makes sense? And it also does it if my cars on idle And I rev it once it hits up near 6000rpm again It stops it self in a centain respect Just wondering if anyone else has had this problem etc Or if need to no more about my car just ask ThanksAlso my cars a ep91 if that helps Chand Quote
Hawaiiviper Posted May 17, 2012 Posted May 17, 2012 I've experienced something similar and it was my plug wires so could be ignition related. Check plugs, wires, distributor cap and the contacts and make sure free of corrosion. Quote
Chand Posted May 17, 2012 Author Posted May 17, 2012 Il check everything as soon as I get chance Thanks and it's a turbo but im running a td05 hybrid Quote
Chand Posted May 19, 2012 Author Posted May 19, 2012 I had my car remapped today As its seemed to have solved th problem as far as I am aware They said that as the fuelling was out Once it got up near 6000 rpm it spiked a bit So as the fuelling was out it caused it to run safe as such Thanks for advise and help though Hope this maybe help others tooChand Quote
