Will a standard Glanza clutch and flywheel fit into my N/A sportif gearbox?
Want to use this box rather than shelling out more on a Glanza box...
Edited by Zeldoz
I tried doing this but what we think was a faulty pressure plate prevented gears from being selected.
As long as you use a matching clutch and flywheel technically it should work. Good luck as I'm hoping to re-attempt this in a few weeks!
I'm buying the standard flywheel and standard clutch from GTBitz.. I'm hoping it would work... Because the N/A clutch would shit itself...
the N/A gearbox will last for ages, just depends on how agressive your driving is...i put both my boxes through hell with the 4E-FE and there still perfect
change the oil to something decent, make sure the shifter bushes/engine mounts are not damaged and youll be fine
