Zeldoz Posted May 18, 2012 Share Posted May 18, 2012 (edited) Will a standard Glanza clutch and flywheel fit into my N/A sportif gearbox?Want to use this box rather than shelling out more on a Glanza box... Edited May 18, 2012 by Zeldoz Quote Link to post Share on other sites
Amjad Posted May 18, 2012 Share Posted May 18, 2012 I tried doing this but what we think was a faulty pressure plate prevented gears from being selected.As long as you use a matching clutch and flywheel technically it should work. Good luck as I'm hoping to re-attempt this in a few weeks! Quote Link to post Share on other sites
Zeldoz Posted May 18, 2012 Author Share Posted May 18, 2012 I tried doing this but what we think was a faulty pressure plate prevented gears from being selected.As long as you use a matching clutch and flywheel technically it should work. Good luck as I'm hoping to re-attempt this in a few weeks!I'm buying the standard flywheel and standard clutch from GTBitz.. I'm hoping it would work... Because the N/A clutch would shit itself... Quote Link to post Share on other sites
Amjad Posted May 18, 2012 Share Posted May 18, 2012 Cool, keep me updated! An FE clutch will not handle my driving on track lol Quote Link to post Share on other sites
neilsmith Posted May 19, 2012 Share Posted May 19, 2012 I've done this it fits and works fine, lasted about 5000 miles before it went pop Quote Link to post Share on other sites
Zeldoz Posted May 19, 2012 Author Share Posted May 19, 2012 I've done this it fits and works fine, lasted about 5000 miles before it went popWhat went pop and why? Quote Link to post Share on other sites
Zeldoz Posted May 19, 2012 Author Share Posted May 19, 2012 Bump? Quote Link to post Share on other sites
Asad Posted May 19, 2012 Share Posted May 19, 2012 the N/A gearbox will last for ages, just depends on how agressive your driving is...i put both my boxes through hell with the 4E-FE and there still perfectchange the oil to something decent, make sure the shifter bushes/engine mounts are not damaged and youll be fine Quote Link to post Share on other sites
