Have a gt use it as my daily about 40-50 miles a day most of that on the motorway and I always find the level dropping slowly but nothing major is this all good ?
Your car should 'use' ANY coolant...
So you may want to check:
Radiator, Rad Cap, Overflow Bottle and Pipe
Turbo Water Lines
Headgasket Check??
Obv when up to temp things expand and pressure up so may not be noticable at a glance when cold!
Ow sheet when the word headgasket crops up I shit meself. :( I'll get it checked but its defo using coolant would a small amount of white smoke on idle when warning up in the morning have anything to do with this ?
Ohh I see thanks hope its somthing small it's not using masses top it up every month or so and it's not smoking at all another time I hope it's not the head gasket would be devastated
