ok on my ep91 when ever i tighten my drivehaft nut the whole side locks up on me and is extremely hard to move. Does anyone know if behind the lug nut there should be a spacer / washer or something??
Any info appreciated .... Many Thanks
There shouldn't be anything behind the nut, but it should have the safety cap and split pin after it
Cheers for the reply mate :) Hmm not a clue why this side is locking up then :S Ive had new stub axel new bearings and now when tightening back up i cant gudge that side unless i break it off a little and even then its rreally hard to move.
It was easy to move when the driveshaft was only half inserted into the bearing
Any ideas dude?
i JUST LOOKED AND WHEN TIGHT IT LOOKS LIKE THE abs RING ON THE SHAFT IS TOUCHING THE YELLOW COLER ON THE BACK OF THE BEARING SURELY THIS SHOULD NOT BE LIKE THIS??
Sorry caps lock :(
