Hi folks away to change the front discs and pads at the weekend, is there any problems/ anythng different that i shld be looking at etc. because my car has ABS ????
youll be fine, use copper grease on the back of the pad/edges....make sure the sliding pins are free/put all the bolts in by hand first then tighten down...clean the disc with brake cleaner before you put it on etc etc...let us know how you get on :)
