Basicaly i have had the engine out of my glanza and rebuilt it put it back in and i have problems i would realy appreciate it if someone could help me :)
1. Water leak from the hard water pipe at the back of the block i think theres meant to be a pipe that goes from it to the inlet but not sure ?
2. Beeping noise from the inlet area ? I uploaded a vid and someone pointed out that it could be something loose but im sure its something electrical
3. Strange idol, it revs from 500 to 2000 rpm on ticover ?
4. Engine management light
Could these be related to each other ? Please help me someone haha
You have a split vac line hence the hunting (when idle goes up and down.
Hard water pipe is either the o ring seal at the water pump end or one of the two hoses coming off it.
Do a manual diagnostic check and you will find out why the engine light is on. the beeping is probably related.
Edited by shorty
