el_man Posted June 8, 2012 Share Posted June 8, 2012 As above power boost wise? what options do i have also?While we on the subject what cams are about that wont hurt my pocket so much? Quote Link to post Share on other sites
AdamB Posted June 8, 2012 Share Posted June 8, 2012 I thought Aze had his head lift at 1.6 bar on a big turbo lol. Options are to run 4AGE headstuds, get the block drilled and tapped to suit, along with the cylinder head and head gasket. Bit of a pain. I'm doing the headstuds because I know when it's done, no matter what turbo I want to throw on there it will take it.Try Tighe cams, I got a spec sheet for their cams and they do a wide range for the 4E motor, can't remember the price without checking my emails but I think they are about £500. Quote Link to post Share on other sites
turbo Grant Posted June 9, 2012 Share Posted June 9, 2012 It's a pain bolting the head down with the 4age studs in haha. Will take 2.4 bar with the studs in. It's more to do with ignition timing when running big boost. You get some knock and the head gasket takes the blow. Quote Link to post Share on other sites
AdamB Posted June 9, 2012 Share Posted June 9, 2012 Did you grind some of the head away where the nut goes on the stud Grant? It is a major ball ache to do, but once its done, its done for good Quote Link to post Share on other sites
turbo Grant Posted June 9, 2012 Share Posted June 9, 2012 Not a big ball ache. 15mins with a die girder and your there. Then you can fit the socket on the nuts. Only really need to do one side and cut the studs down under the cam gears Quote Link to post Share on other sites
