Starbo Moorley Posted June 10, 2012 Posted June 10, 2012 (edited) After replacing my turbo because of failed oil seals, went for a drive too setup the boost at 1st it boosted too 20 psi so i adjusted the the actuator and went too run it again and it boosted too 18psi, it then decided to blow the exhaust mani to turbo gasket and wouldnt make actual boost till 4k.Ive changed the turbo (again cause the last one was faulty too) and replaced the gasket so the exhaust isnt blowing at all now, but it still wont make boost until 4k rpm :/.Im thinking it could be a boost leak but then surely it wouldnt boost at all ?Any ideas ?? Edited June 11, 2012 by Starbo Moorley Quote
pick1 Posted June 10, 2012 Posted June 10, 2012 Check all vac lines mate etc check for any hissing noises of any and check all mani to exhaust etc are on tight and not leaking mate Quote
ep91steve Posted June 10, 2012 Posted June 10, 2012 Could of been a boost leak in the 1st to hit 20psi and 18psi Quote
Starbo Moorley Posted June 10, 2012 Author Posted June 10, 2012 It still pulled from 2.5k till the gasjet blew Quote
Starbo Moorley Posted June 11, 2012 Author Posted June 11, 2012 Sorted it now! actuator was sticking Quote
