I have a WEPR external Wastegate ct9 manifold here it needs the studs retreaded as they are wrung though. PM me an offer
I would fancy td04 but I like the quick spooling of ct9, how
Much you looking for out of interested
As for the ct9 Mani, how do you mean wrung through mate, and will it keep the turbo in stock location?
Whoever took the manifold off the car cross threaded the bolts that slot into the ct9 turbo flange so they will have to be replaced. It keeps the turbo in the stock position I will get you pics tomorrow
@td04 glanza, not a bad price mate, still unsure if i wanna go td04 though man :/
@Browner, ah I see, so could I worst case get the studs drilled out and use nuts and bolts?
But yeah pics and a price would be good if its direct fit
I probably won't but its just more cash as i've already spent enough on CT9 bits, also I'd need to getit mapped whereas CT9 I can just use a PnP mate.
Hmm, i reckon ill try ct9 hybrid at 1 bar for now and see if i get bored lol
I ran standard ct9 at 1bar 1.2 special occasions was awesome on spool up and the chatter I got from that little turbo was so loud :)
Edited by akyakapotter
Yes mate they could be drilled out and replaced with nuts and bolts or perhaps re-threaded with a tap and die set
Uploading pics now
