Weyro Posted July 6, 2012 Posted July 6, 2012 Is there any way to stop the HKS EVC I've from adjusting boost offset by itself.Currently have it at 114 but it keeps putting its self up ever so slowly. Quote
A L 3 X Posted July 29, 2012 Posted July 29, 2012 What does the offset do? ISnt this just for external wastegates? Quote
akyakapotter Posted July 29, 2012 Posted July 29, 2012 Which one do you have mate as I know there is a setting that learns the turbo and ups it to keep the pressure at say 0.9 as the turbo get older makin it work harder id say that feature is turned on Mate. Quote
A L 3 X Posted July 29, 2012 Posted July 29, 2012 I've got the profec a mate which does have a learning feature, which I'm assuming isnt working right because I have to back off before full boost as it'll cutIf I link to the manual will u have a look for me please mate as i cant understand it? Quote
A L 3 X Posted July 29, 2012 Posted July 29, 2012 Sound cheers mate:/>http://www.greddy.com/upload/file/PRofec_A.pdfI've got the most part understood but it's all this offset and the selector switches on the back? Just want it not to creep lol but I think I'll need an ew Quote
akyakapotter Posted July 29, 2012 Posted July 29, 2012 An man that is more complicated than what I use sorry dude I'm not going to be much help on this one Quote
Weyro Posted July 29, 2012 Author Posted July 29, 2012 (edited) The offset on mine is how aggressively the Controller will find peak boost.100 is NeutralYour turn it down to say 80, which will make it spool quicker, but also more likely to overboost.Turning it up, to say 120, will make it take longer to reach peak boost, but less chance of overboosting.(on an external gate its the other way around)The EVC I've, will adjust itself slowly if you over or underboost, which is annoying, for me I found out to turn off the feature, you turn the car on, turn the evc off, hold MOD, and switch the SW-PO switch, then let go of MOD and switch it back.note: damn forum keeps changing I V to i've Edited July 29, 2012 by Weyro Quote
A L 3 X Posted July 29, 2012 Posted July 29, 2012 Ah I see, I dont think my issue is the same then, because my manual says offset(for external wastegates only) so maybe is only adjustable when you have an external oneI think my issue must be just due to the fact my car is creepiing anyway? Quote
Weyro Posted July 30, 2012 Author Posted July 30, 2012 Does it creep when you run without the ebc, just a pipe from turbo to actuator? Quote
