steve-gers Posted July 10, 2012 Posted July 10, 2012 I was just wondering if this would fit and work fine on the 4EFTE as if it worked it would be a good solution for those wanting a port for an oil temp/pressure gauge but not for both unless there is some kind of splitter available for 2 ports. Quote
WallaceGlanza Posted July 10, 2012 Posted July 10, 2012 (edited) Yes, it's exactly what I use.Edit: It's not good for temperature readings though as you need the sensor for it where the oil is flowing. Edited July 10, 2012 by WallaceGlanza Quote
