So that one definately works?
What parts do I need exactly, put simply so an idiot like me can understand.
Yes it defo works, i verified it with a mityvac pressure pump, and im currently using it on my own car. All the parts needed ar listed in my guide. All you do is dissonnect the oem map sensor, amd wire the VW one in its place.You need fc-datalogit to change the settings for the map sensor tho you cant do it with the hand commander
