A L 3 X Posted July 27, 2012 Posted July 27, 2012 Just wondering if anyone can help me to install this.Obviously I know one hose goes to actuator, one to turbo, and one to inlet mani for boost reading, but I'm unsure what settings to use on the actual controller to be safe.Could anyone take a look at the manual and tell me:/>http://www.greddy.com/upload/file/PRofec_A.pdfCheers Quote
A L 3 X Posted July 27, 2012 Author Posted July 27, 2012 Anyone, it's mainly the dip switches and offset and ratio?Cheers Quote
A L 3 X Posted July 27, 2012 Author Posted July 27, 2012 Right, have read through the instructions for the 4th time and start to understand it, as I understand it offset is only relevant to external wastegate setups and should be left in the middle, is this right, and what actually is offset?Also, is the overtake boost the same as the hi boost mode? Quote
1990timeismoney Posted January 26, 2013 Posted January 26, 2013 Hi did you have much luck setting your greddy controller up ive had one before and set it up fine ive now got another and i just cant get it to set up nor will it work in setting up in manual mode.any advice would be great. Luke Quote
