armymanmike Posted July 28, 2012 Posted July 28, 2012 Need help. Asap . Any easy ways to change the clutch master cylinder asap help thanx. by the way gt 1995 Quote
micky boy Posted July 28, 2012 Posted July 28, 2012 (edited) They should be all the same GT/Glanza and NAThey should be 2 10ml blots take them off then they should be a pipe that go's into the master cylinder thake that out and that should be it!Just do the same puting the new one on give it a bleed job done...To start bleeding it push the master cylinder in and it should start the system offYou will need a friend to help you as one will need to press the cluch in why one bleedsEdit oops dont know why but for some reason i thought you ment cluch sleeve cylinder May bad lol Edited July 28, 2012 by micky boy Quote
jtaylor1990 Posted July 29, 2012 Posted July 29, 2012 Well turns out there are two 12mm bolts holding it from the drivers side under dash, so we sorted it, but the master cylinder wont bleed so now means gotta wait for the new one to turn up, I did already have a new one but the company sent the wrong one in the box, so now have a dead car on my drive and no way to get to work ffs Quote
