scoobykilla Posted August 16, 2012 Posted August 16, 2012 Not sure if this is the right place but here goes.rear wheel bearing is needing replaced on my V, what size is the hub nut on the EP91's, is it a 28mm? also will i need a deep socket for it? Quote
morgey Posted August 16, 2012 Posted August 16, 2012 30-32 it depents if theyve been replaced, i have both on mine, and i can manage mine with a standard socket in a halfrauds tool kit ;) Quote
StuDoc 72 Posted August 16, 2012 Posted August 16, 2012 Standard socked for the back deep one for the front. You shoudnt need a socket for the rear as its tapered bearings on them so shudnt be tight anyway. Probly best to have one in any case i guess Quote
