CookieMonster Posted August 20, 2012 Posted August 20, 2012 Hi Guys,Just a quick one, when driving home, my speedo lights went off(but door, air bag lights still are on) but my head lights still work. Also, my rear brake lights are also off. Could this be fuse related by any chance? Anyone else had this issue? Quote
Socks Posted August 20, 2012 Posted August 20, 2012 yes. it is a fuse...10amp under steering wheel lad! Quote
CookieMonster Posted August 20, 2012 Author Posted August 20, 2012 Thanks Socks lad, i will take a look when i get home tonight. Quote
CookieMonster Posted August 24, 2012 Author Posted August 24, 2012 Ive checked the fuses and the one that states Gauge, looks fine (no break inside the fuse) but the one for Tails is broken inside. Are these connect together as i took out the Tails one and yet the gauge lights still dont work. It that right Socks lad. Quote
har-vey Posted August 24, 2012 Posted August 24, 2012 im haveing the same problem but mine turn back on after a few mins, would this be a loose conection? Quote
Socks Posted August 24, 2012 Posted August 24, 2012 cookie... ignore what it says... the front fogs, rear lights and instrument dials r on same fuse i assure you... change it if its blown ull be finehar vey, yes, loose connection! Quote
CookieMonster Posted August 24, 2012 Author Posted August 24, 2012 Socks, Thanks fella, i will get the fuses tonight when i finish work from somewhere Quote
Socks Posted August 24, 2012 Posted August 24, 2012 Socks, Thanks fella, i will get the fuses tonight when i finish work from somewhere Look in the lid of the fusebox under engien bay may be spares in there! Quote
