Hi guys, I've had an ongoing problem for the past couple of years. My passenger side caliper tends to stick. I'll use the brake and the caliper will stay on a bit, making the brake disc VERY hot, slows the car down a fair bit and drinks the fuel so its quite a problem.
When it first started I would take the caliper off, lube up the slides and also press the brake while the caliper was off as it was the actual piston that kept sticking, the wind the piston back in with a G clamp.
Anyways, I kept doing this everytime it happened.
Then I got another second hand caliper and replaced the existing one, it was working fine for a few months now its done it again.
I'm just wondering what the best solution is? would a caliper service kit be enough, do I buy another secondhand caliper or is it a case of buying a new caliper?
A service kit is £25 for the pair, a secondhand caliper is around £20-£30 each and new calipers are around £70-£130
New Caliper
Secondhand
Service kit
cheers guys
