Went to fit my hks actuator, but noticed the standard actuator has two boost pipes coming off it, yet the hks only has one? How do i get round it?
Cheers
If you just want to run the boost set by the actuator, ie no boost controller or hi/lo then just loop one short hose from the turbo nipple onto the actuator nipple.
As new the hks actuator kit comes with a tee piece to allow you to still run the stock hi lo solenoid or a boost controller.
See im running a boost controller aswell, will be setting that up tomorrow aswell like. Want to be running slightly more boost than normal. So its a little bit quicker thats all :D not too much tho, just had a new engine :/
