jonnygt Posted September 13, 2012 Share Posted September 13, 2012 Went to fit my hks actuator, but noticed the standard actuator has two boost pipes coming off it, yet the hks only has one? How do i get round it? Cheers Quote Link to post Share on other sites
StuDoc 72 Posted September 13, 2012 Share Posted September 13, 2012 The loop from your turbo goes onto the vac nipple on the HKS actuator the other pipe can be removed as its for the high low boost solenoid. Quote Link to post Share on other sites
jonnygt Posted September 13, 2012 Author Share Posted September 13, 2012 Thanks mate. So if the hi/low boost pipe is removed will it be on high boost all the time? Quote Link to post Share on other sites
StuDoc 72 Posted September 13, 2012 Share Posted September 13, 2012 Yes mate will be on whatever boost pressure you set the HKS actuator to. Longer = Less boost. Shorter = More Boost. Quote Link to post Share on other sites
jonnygt Posted September 13, 2012 Author Share Posted September 13, 2012 No worries. Thanks mate! Nice one Quote Link to post Share on other sites
StuDoc 72 Posted September 13, 2012 Share Posted September 13, 2012 No problem mate. Quote Link to post Share on other sites
jonnygt Posted September 13, 2012 Author Share Posted September 13, 2012 Any one got any pics of these fitted? Just so i can see the pipework n that properly! Thanks Quote Link to post Share on other sites
StuDoc 72 Posted September 14, 2012 Share Posted September 14, 2012 Mate there is only that one pipe. What pipe work are you talking about? Quote Link to post Share on other sites
WallaceGlanza Posted September 14, 2012 Share Posted September 14, 2012 If you just want to run the boost set by the actuator, ie no boost controller or hi/lo then just loop one short hose from the turbo nipple onto the actuator nipple.As new the hks actuator kit comes with a tee piece to allow you to still run the stock hi lo solenoid or a boost controller. Quote Link to post Share on other sites
jonnygt Posted September 14, 2012 Author Share Posted September 14, 2012 See im running a boost controller aswell, will be setting that up tomorrow aswell like. Want to be running slightly more boost than normal. So its a little bit quicker thats all not too much tho, just had a new engine :/ Quote Link to post Share on other sites
