jonnygt Posted September 16, 2012 Posted September 16, 2012 Just had new engine in, but these are not working now. Engine is out if a automatic glanza. Will this matter?? They were fine before. Could it be a fuse? Which fuse box, under bonnet or in car? Cheers Quote
bucketep91 Posted September 16, 2012 Posted September 16, 2012 Have u checked the speedo cable is connected up properly at the gearbox?Theres a little spade connector on the thermo housing that sends the signal to the temp guage id check that out tooCharlie Quote
yaristurbo Posted September 16, 2012 Posted September 16, 2012 Make sure you haven't pulled the cable out the clocks while fitting all so And as above for the temp, but these looms are getting old now and could have easily snapped on a bend Quote
jonnygt Posted September 16, 2012 Author Posted September 16, 2012 Ok wil check them out. Cheers Quote
