gtizz i Posted September 20, 2012 Posted September 20, 2012 Hi everyone am sorry if ive wrote this in the wrong section but i didnt know where to put it so the problem is that my ep82 pulls to the right most of the time and am getting confused by could it be the tracking or could it be something else? And secondly when am doing 30 mph and over i get a noise i find hard to describe but il try my best its like a grinding noise but dont know what it could be? Need your help guys thanks. Quote
morgey Posted September 20, 2012 Posted September 20, 2012 The pull could be tracking, Wheel bearing maybe even a seized brake caliper. Grinding could be bearing, low brake disc or heat sheild/dust cover rubbing on disc Quote
grum-glanza Posted September 20, 2012 Posted September 20, 2012 Check all your bushes anti roll bar, drop links, tie rods I no my car was pulling to the left it ended up being a worn front wishbone rubber Quote
morgey Posted September 20, 2012 Posted September 20, 2012 Tyre pressures, wheel balancing... Could be loads of things, make a list and start with the easiest /cheapest Quote
StuDoc 72 Posted September 20, 2012 Posted September 20, 2012 Sounds to me both the problems could be because of your brakes but as said above could be any of the mentioned. Quote
starlet87 Posted September 20, 2012 Posted September 20, 2012 mine was pulling to the left and found out that my brake caliper had seized so sorted that and now its fine Quote
*Zoe* Posted September 21, 2012 Posted September 21, 2012 (edited) I'd check tracking and tyer pressure first, and when you've been for a bit of a drive stop and hover your hand near the each caliper ifs one / two are way hotter then the others could be seized on. and wheel bearings to you might get lucky mine was grinding abit and just nipped them up so cheap as chips Edited September 21, 2012 by *Zoe* Quote
