My dash clock keeps going off, if you give the dash just above the clock a whack it comes back on, or occasionally it comes back on its self, but recently it just stays off no matter what. It also keeps losing time, was reset recently and is now 10 mins behind.
Will this just be a loose connection? Or will i need a new clock? If it needs a new clock, how easy are they to change with the dash still in place?
Cheers
the clock as in time clock... not your speedo clock?
if you mean your time clock, whip the clock out and insure the connector is clipped into the socket. Failing that replace it.. .There not rare or expensive from many breakers!
Yea i meant clock as in time. Was mainly wondering how difficult they are to remove, didnt want to break clips etc. but shall try popping it out and try the connectors ta
