akyakapotter Posted October 7, 2012 Posted October 7, 2012 Hey every one its my local drag / drift day on the 13 my question is what tire pressure should i rock cheers people Quote
Jack-CTR Posted October 7, 2012 Posted October 7, 2012 i.tend to run 20-22 psi depending on weather and surface.conditions and adjust up.and down.accordingly, Quote
akyakapotter Posted October 7, 2012 Author Posted October 7, 2012 Awesome thanks for that bud see if I can get my power down this time lol Quote
Jack-CTR Posted October 7, 2012 Posted October 7, 2012 what power you running?try launching soft then.planting itlaunch hardlaunch hard but slipping clutch a bit see what works for you,i found hero launchs worked for me Quote
akyakapotter Posted October 7, 2012 Author Posted October 7, 2012 It's just an old air field bud and I'm rocking 233.4 bhp 210 ftlb torque.Will give that ago mate cheers for the advice Quote
Jack-CTR Posted October 7, 2012 Posted October 7, 2012 so tyres will be shredded but a fair bit of grip or no.grip if get unlucky on pebblesput them at 24 do a run or two then if still.spinning drop.the psi a bitkeep doing this untill your terminal speed dropsthen youve got as much grip as going to get wih out sacrificing rolling dragdo a few runs at each pressure tho Quote
akyakapotter Posted October 7, 2012 Author Posted October 7, 2012 Tires were fine last time I done it still as good as new lol will try that bud see if I can better my times from the last one Quote
Jack-CTR Posted October 7, 2012 Posted October 7, 2012 (edited) your not trying hard enough then if tyres are fineif your not shredding them your not doing a good enough burn out and man launchs Edited October 7, 2012 by Jack-CTR Quote
akyakapotter Posted October 7, 2012 Author Posted October 7, 2012 No point mate only one wheel will spin no LSD yes I no I'm mad lol last time I was pruning 1st 2nd 3rd Quote
Jack-CTR Posted October 7, 2012 Posted October 7, 2012 yeah I've not had an lsd till y day, can still get some heat in themwiggle steering wheel.lots hard to disrupt the tyres and get both spinning a bit Quote
