As above guys, seems like every time I go into first it seems like it gets stuck. I have to pretty much stop in the road and push down the clutch an pretty much wiggle it about until it goes in. I'm looking at going bigger power next year so considering getting new clutch and flywheel anyway but want to check if there's something I can do to fix problem just now before it gets worse
Look in your engine bay to the back right hand side, there are two cables attached with circlips, ensure that these are on properly. Does it engage ok when the engine isnt running, if it does then its unlikely to be aproblem with the gear linkages.
Unfortunatly if its not the linkages it could well be a knackered box, they are cheap enough anyway to buy on here for about £80-£100. :)
