Draining my gearbox and changing the oil in it tomoro or wednesday but i cant see where you drain it from and fill it from ? any one point me in right direction as ive never changed gearbox oil ?
cant go wrong mate theres a 24mm drain plug on the bottom and half way up the gearbox is a 24mm plug to fill it up. take out the plug to fill it up when you drain the oil :)
so ive drained and filled my gearbox used 2 liters of redline gearbox oil only thing is it didnt trickle out of the middle bolt ? ive put 2 liters in but dont know what to do is it safe to drive with that or should i order more ?
