have the above boost controler in my car it wont go over .6 bar have it connected correctly evin tried switching the pipes around stil the same there is power goin to the solonide..would the solonide be stuck as it came out of a running car..any help greatfull
have you the control unit set right to your setup? theres a switch on the back for either internal wastegate or external wastegate
yes evrytin set up right switch is set for actuator..its the solonide..just wondering do they go stick ect?
