rumaray Posted October 18, 2012 Posted October 18, 2012 got a problem since i had my car....before that i saw al those threats about itthe problem is crunchin in gear 1 .2 . lil bit in 3 ...and the reverse OUCH ..i must pump the clutch several times anto after some struggling is going in the first gearand when i go in HIGH RPM's they won't get in those gears....when i drive slowly normaly then it wil go into gears.....got 2 questions .... i thinks that i have problems with the flywheel, because evrything that can be a problem is all fixed1 - i have a 4e flywheel ACT ....can i fit it on a 5e ? ( don't know its a stupid question)2 - if it is the flyweel can a bought a stock 5e flywheel ? Quote
Amjad Posted October 19, 2012 Posted October 19, 2012 I think people use the 3e flywheel to use a 4e clutch on a 5e engine? Quote
honda killer Posted October 19, 2012 Posted October 19, 2012 yes 3e flywheel and 4e clutch or else get your standerd 4e flywheel bored to suit the 5e crank..did u try bleeding the slave cylinder?or your relase bearing fork could b shot!! Quote
rumaray Posted October 20, 2012 Author Posted October 20, 2012 we have trying to bleed the cylinder they have lilbit of air in but we have fix that..... Quote
