What is the Advantage of using a thicker Head Gasket?
At WOT you should probably be looking to run a target AFR of 11.2-11.5:1, get it checked with det cans as its not as simple as increasing the fuel pressure makes your engine safe. Detonation is the biggest killer of engines and will destroy it in seconds.
Exhaust gas temperature is mainly dependent on the intake charge temp, the higher the temp, the higher the output of gas temp. Not only that but higher intake temps increase detonation. Reduced temperatures=more power.
