Drive shaft/cv joint any condition EP91 bonnet catch support
What i need is just the end that goes through the wheel bearing i want this to put in while i wheel my car about when it's having some work done.
Also i want the bar that support the bonnet catch run from the bottom up to the top support bar think people remove these whan fitting big coolers so might be a few about.
Simon, the car will roll and turn fine without the CVs. I have the bar you need here, £13 posted. :)
Cheers
Idrees
ID-Workz
