hi guys does anyone know of an engine removal guide for the glanza? ive tried to find 1 and have come across and engine building 1 but not and engine removal guide if someone could help!!!!
what are you stuck on matey, if you let poeple know we can give advice
Aaron
i have recently brought a 5e engine mate and want to do a conversion so the 4e needs to be removed i was after a guide to remove the engine from start to finish i have been looking around and found engine building guides just wonderd if anyone knew of an engine removal guide so i can follow it and take mine out
I am so good :)
"How to remove a 4efte engine guide"
/>http://www.toyotagtturbo.com/forums/showthread.php?16067-How-to-Remove-an-Engine-Guide-*
I did it for the 1st time using this guide, it covers nearly everything. Basically just unplug everything :) Take some before pics to help put it back together :)
will do mate ive just realised it was your engine building guide lol how did things work out with the engine in the end? how long did it take you to take the engine out? did you take the gearbox out with the engine?
