davehart Posted November 11, 2012 Posted November 11, 2012 Do these units have a fuel / boost cut setting like the stock ECU's? Quote
davehart Posted November 11, 2012 Author Posted November 11, 2012 Right, that's strange then because I hit mine tonight booting it from 3rd. This was in the GT4 though not the starlet.It sure felt like fuel cut. Looked at the boost controller and it peaked at 1.33 @ 5125.Stock cut is at 1.2/1.3 on those so wondering if the units had a fuel cut feature or when piggybacked didn't always blank out the factory ECU setting. Quote
Jack-CTR Posted November 12, 2012 Posted November 12, 2012 id imagine they have one but during mapping its raised/turned off? Quote
Danb Posted November 12, 2012 Posted November 12, 2012 (edited) id imagine they have one but during mapping its raised/turned off?correct its increased Edited November 12, 2012 by Danb Quote
AdamB Posted November 12, 2012 Posted November 12, 2012 I'm sure you have to adjust the voltage which it clamps at as it is determined by the map sensor. Quote
davehart Posted November 12, 2012 Author Posted November 12, 2012 correct its increasedRight, I'll have a guess mines set to a safe 1.3 bar then Quote
