daveEP Posted November 14, 2012 Posted November 14, 2012 hi!! looking for a bit of help here. i put a post up about oil n water mix and its my head gasket im sure. i took the head off tonight and when i looked closer at the head gasket it was round the right way but was totaly covering some of the ports for water/oil to run up to the head. is the gasket ment to cover any of the water or oil ways once its on or do i have the wrong gasket? any help would be grait. cheers dave. Quote
starletburkie Posted November 15, 2012 Posted November 15, 2012 is it a toyota gasket? some of the waterways are blocked to aid warm up Quote
Idrees Posted November 15, 2012 Posted November 15, 2012 As above, some of them are meant to be covered up. CheersIdreesID-Workz Quote
daveEP Posted November 15, 2012 Author Posted November 15, 2012 klkl i wasnt to sure. just needed reasurence. that solves that. idrees i will get in contact with u on monday to order they head bolts!! Quote
alan ball Posted January 20, 2013 Posted January 20, 2013 if head is level you should be able to see where the oil or water has mix a water mark i think there should be holes cover up mate Quote
PaulStarletSR Posted January 21, 2013 Posted January 21, 2013 if head is level you should be able to see where the oil or water has mix a water mark i think there should be holes cover up mate jeez,your late on this lol hes sorted it, vac lines were on wrong way Quote
