hey i had a broken mount a few months back but they guy must have done a crappy repair because it was cracked and it apparantly put pressure on the gearbox. the gearbox is now cracked and is leaking oil, i was jus wonderin if anyone knws how much a recon gearbox would be and can i put a corolla gearbox in my car?.
Toyota Starlet SR 1999 1.3
the gearbox from a 4efe rolla will work mate. so thats cool. a second hand box will cost you a few hundred quid aswell.
although you should persue the garage who repaired it, as its their shabby work that went wrong and they should sort it out.
Is that £135.00 for a recon'd box? As mentioned it would be wise to speak to the garage as they are partially to blame. You can use the box from the G6 Corolla with no problem at all. You could also use a GT/Glanza box (non stock LSD) although the ratios won't be suited to the 4efe.
Cheers
Toby
