The knock sensor only has one wire on the plug and I've seen them get damaged, so double check that the wire doesn't have any nicks or splits in it. The sensor is under the inlet manifold on the right side (when looking from the front of the car) at the back of the engine.
If you do need a new one then drop me a PM (thanks Jono).
