engine code 52 knock sensor help needed
  On 11/25/2012 at 9:31 PM, Jonophilpott said:
http://www.camskill....o_EP82_and_EP91
Ask id-workz hes your man for cheap genuine parts
ok thanks ill send him a message.
will it still be ok to drive.how do you reset the codes as i cant find the efi fuse in engine as all the writing has been removed,.
thanks
The knock sensor only has one wire on the plug and I've seen them get damaged, so double check that the wire doesn't have any nicks or splits in it. The sensor is under the inlet manifold on the right side (when looking from the front of the car) at the back of the engine.
If you do need a new one then drop me a PM (thanks Jono).
