Have searched high and low with no luck.
Going to fit my spoiler with tiger seal as no holes in it for bolts (idz rep second hand).
Any measurements of where should put it?
Anyone got some close snaps to help me?
Thannnnkkkkkssss :D
About 2-3 mm under the window put the bolts into the spoiler and put masking tape on the boot it will leave a mark on the tape drill the holes
But the two outer ones you won't be able to see from inside it's double skin there you will need to drill out 20-25 mm holes inside the boot and get rubber gromits
