All warning lights coming on till car is restarted, help
Made it home in one piece, happened loads of times though.
The battery, oil and abs lights come on. If i accelerate hard the battery and oil light go off but the abs light stays on till i restart the ignition.
Only thing ive done to the car recent is bleed the clutch, I did spill some fluid when topping up, so maybe thats going into the alternator?
Also, when starting from cold, the battery and oil light are on, then if i rev it they go off after a loud squeel from the engine bay
Either your alternator belt is slack as a porn starts cunt!
Or your alternator.or battery are on there way out!!!
But you have said there a loud squeel from the engine bay so my gess is your alternator blet isnt tight enough!
Gave it a check, seems tight enough, but theres some oily residue on the underside of the belt, im gonna take it off and give it a clean, then re tighten it. Hope its not the alternator lol
