Hi all.
I’ve just brought a Aem wideband brand new from aem.i was having fuelling problems so brought this to help.
First of my walbro fuel pump wines but only when engines on i no its normal noise but i thought it also would wine when the key is in the on position to build pressure.
When it idles its at 14.7 but when i turn my lights on it goes to 16.2.
I then go to accelerate and the gauge goes to red. I’ve set the fuel pressure to 3 bar with vacuum line off and running 0.7 bar on td04 turbo setup.
If anyone has any information or help on how to fix or what’s wrong it would be much appreciated.
Thanks
hi what im trying to work out is why when i accelerate the car is running lean 16.7 and when it idles its at 14.7. which I've been told is ok
Does fuel pressure need to be set with vac line of or on.
i set the pressure higher and still the same engine management light has come back on knock sensor issue.
Ive also set the calibration dial on the aem gauge to p4 and still the same,
Was hoping to get it mapped next weekend by TD but as i cant even get it to run rite looks like it could be next year at this rate.
