What is the sensor that sits in behind the manifold near the right had side of the engine. It's near to the slave cylinder on the gearbox it's a kind of bar with a ball on the end and the plug just pushes onto it. Need to know as I broke the connector off it when removing it and need to figure out a way of fixing it.
Ok thanks very much. This has never worked since I bought the car so not a big issue although I may aswell repair it now the engine is out. I was thinking of screwing a big bit of connector block over the sensor then cutting the plug off the connector, stripping the wire and putting it in the other side of the connector block as a fix. Bit pikey but only thing I can think of.
