As above it will fit, the only difference is the UK spec top mounts have 3 studs and the Glanza has 4.
Glanza has 3 studs iddy GT has 4. Theres 4 holes on the Glanza tho.
Had to change my Ep91 top mounts for EP82 ones.
Edited by StuDoc 72
ep91 n/a has 4 holes on the front also?? :s theres just a plastic bung in it? how else do people get meisters on their n/a's?
i had meisters on my n/a and they have 4 studs on their topmounts
I said there was 4 holes. But standard Glanza top mounts have 3 stud.
Please read it correctly before jumping down my throat.
Edited by StuDoc 72
yeah so its doesnt matter wether the top mount has 3 or 4 holes so why did you have to change the topmounts from ep91 to ep82
im not jumping down your throat, just saying they are all interchangable doesnt matter if its ep91 or ep82
Had to change them due to the shockers were off an EP82 and the collar at the top of the shocker rod was slightly bigger in diameter and didnt fit through the spring plate for the EP91.
Pointing out that the different top mounts makes no difference to the car.
Regardless It doesn't matter we are both saying the same thing. YES all EP91 and EP82 shockers are interchangeable.
Edited by StuDoc 72
