lewisg Posted December 13, 2012 Posted December 13, 2012 as said above any of you got a wastegate for sale cheers
wickedep Posted December 14, 2012 Posted December 14, 2012 any 38mm tial, turbosmart or ebay copy will work mate.
lewisg Posted December 14, 2012 Author Posted December 14, 2012 Okay mate what spring will i need im running standard internals
wickedep Posted December 15, 2012 Posted December 15, 2012 that would totally depend on the rest of your set up mate. if your on stock fuel system..then you wont be able to much boost..so 0.6bar spring should be fine..this will allow you to run up to around 1- 1.1 bar. if you've built your set up..then you can run max boost..so a 0.8-1.0 bar spring would be fine. you cannot lower boost less than the base spring pressure...i.e with a 0.6bar spring you cannot go any lower in boost...so choose accordingly mate.
lewisg Posted December 15, 2012 Author Posted December 15, 2012 Thanks for your help mate. So when you say 0.6 spring does that actually mean 0.6 bar boost? For fueling i have rising rate fpr 330cc injectors and going to get a walbro fuel pump.
wickedep Posted December 16, 2012 Posted December 16, 2012 yes thats what it means..0.6 spring = 0.6 bar boost. if you upgrade further with to some sort of programmable fuel controller..either piggy back or standalone..you can bump the boost up safely. many people in UK are quick to forge their motor for td04's..but over here we run 1.4bar (275-280bhp) on stock internals safely. its all down to the tune. you may want to go for slightly larger injectors.
lewisg Posted December 16, 2012 Author Posted December 16, 2012 okay mate thats cool. Do you know if the hks pfc f con ecu will do the job ? just i can get one cheap and its better then none? im not looking to run 280bhp though just like 220 bhp cheers mate
