I ordered a 255lph fuel pump from tuning developments as my car is going there to get mapped on the TD04 on friday. Today I went out to fit it and when I pulled the old pump out, it already has a Walbro one fitted. I would imagine that the Walbro unit is a 255lph one but is there any way to tell if it's less? Also would I be better fitting the tuning developments one or will the Walbro one be fine as it's only 2-3 years old?
Nah, can't hear mine at all even when it is low. Think I will just leave it in and take crimping pliers + connectors with me and if it needs the TD pump then I will stick it in down there.
There should be a part number on the side of the pump if I remember correctly, this corresponds to its flow rate. I think they do a 195 and a 255, but can't remember the part numbers off the top of my head.
The 255lph is rated to something like 450bhp, you should be ok mate. If in doubt change it :)
It will be shown up in mapping if the fuel pump is good enough for the job.
Edited by AdamB
