steviet Posted December 19, 2012 Posted December 19, 2012 Fitted front bumper crash bar last night,but not to sure if its mounted correct. I have the bar bolted at each end to the headlight brackets and in the middle mounted to chassis legs.Is there another bracket in the centre for support?cheers Stevie Quote
turbo Grant Posted December 19, 2012 Posted December 19, 2012 There should be a bracket that bolts to your slam panel support brace Quote
steviet Posted December 19, 2012 Author Posted December 19, 2012 Don't think i have it,would you have any pics,so i know what im after?cheers Stevie Quote
turbo Grant Posted December 19, 2012 Posted December 19, 2012 I will have a dig around see I I can fine one for you Quote
turbo Grant Posted December 19, 2012 Posted December 19, 2012 Not a very good pic. Just pulled it from google. The bar in the middle it bolts too. Most people remove it when a front mount is fitted. But then the bonnet doesn't shut right and looks like its going too fly up when driving. You don't really need to have it bolted too the bumper bar. But the slam pannel support bracket is a must when using standard catch. It's ok when you have pins. Quote
steviet Posted December 19, 2012 Author Posted December 19, 2012 Ok I see what you mean,I have that bracket in picture but the bumper bar has a bolt fixing in the middle but I don't have a bracket to bolt bumper bar and middle bracket that catch mounts to. Quote
turbo Grant Posted December 19, 2012 Posted December 19, 2012 Will be fine without the middle bolt. I've cut the middle bit out my bumper bar haha Quote
