steve-gers Posted December 29, 2012 Posted December 29, 2012 To help myself and other members in future could anyone that has an aftermarket LSD or a standard LSD box post any pictures they have of them here. I would like to add to a thread so that anyone that is unsure can check which LSD they have or are going to buy. Pictures of the diff on it's own out the box and also a picture through the diff (where the shafts go in) either in or out the box would be very helpful. Also if you could obviously tell me which diff is pictured that would be great. Quote
Ryan-11 Posted December 29, 2012 Posted December 29, 2012 standard difftrd helicalwas told this was a trd mechanical but im not sure Quote
steve-gers Posted December 29, 2012 Author Posted December 29, 2012 This is a cusco mzany pictures of the inside of this by any chance? Quote
AdamB Posted December 29, 2012 Posted December 29, 2012 was told this was a trd mechanical but im not sure That is a cusco mate. The cusco has round holes on the casing. The TRD has oval shsped holes. Quote
yaristurbo Posted December 29, 2012 Posted December 29, 2012 have more if you need The rs diff have coil springs in stead of cone Quote
steve-gers Posted December 29, 2012 Author Posted December 29, 2012 could do with a picture through the diff (where the shafts would go) with it all assembled if you have it? Quote
yaristurbo Posted December 29, 2012 Posted December 29, 2012 Shouldn't be able to see through, button type Quote
steve-gers Posted December 29, 2012 Author Posted December 29, 2012 on teh TRD one I have you can see right through. It's a bit dark inside that picture, what does the other side look like mate? Quote
yaristurbo Posted December 29, 2012 Posted December 29, 2012 Same I believe, I have another stripped at work will get more pics on thursday Quote
steve-gers Posted December 29, 2012 Author Posted December 29, 2012 OK that would be great thanks Quote
morgey Posted December 29, 2012 Posted December 29, 2012 Yea depending on the diff depends in what you see.Stock open diff is a pinStock lsd is a very wide plate with very small gaps either sideThen others are solid plates covering the hole,Plates with various size holes in them etcI guess this is so we can have a reference so we can see what it is we are either buying or selling when getting a gear box or diff? Quote
steve-gers Posted December 29, 2012 Author Posted December 29, 2012 Yeah pretty much mate just to add to that thread you have started and make it into some sort of guide. Quote
