lewisg Posted December 31, 2012 Posted December 31, 2012 Hi do i need a 3 bar map sensor if im only running 0.9 bar boost on a td04 with emanage blue ?cheers Quote
lewisg Posted December 31, 2012 Author Posted December 31, 2012 I have got all the parts to do it just need to fit it all. Emange I got to just wire it in and I notices poeple are using 3 bar map sensors with them cheers buddy Quote
mattyD Posted December 31, 2012 Posted December 31, 2012 I think the standard map sensor is good for up to 1.2bar mate, anything above that and you will need the 3 bar map sensor although it wouldnt hurt to buy one and run it anyway Quote
lewisg Posted December 31, 2012 Author Posted December 31, 2012 Okay cheers where does the 3 bar map sensor wire into anyway just replace with the old one ? Quote
yaristurbo Posted December 31, 2012 Posted December 31, 2012 3 bar is for 2 bar plus as a bar of that is barometeric pressure I believe Quote
Gav_kara Posted December 31, 2012 Posted December 31, 2012 X2 on above hit the nail on it head. Quote
lewisg Posted January 1, 2013 Author Posted January 1, 2013 Beaudifull I can spend 40 on something else Quote
AdamB Posted January 1, 2013 Posted January 1, 2013 3 bar is for 2 bar plus as a bar of that is barometeric pressure I believeIs correct but the stock one is only 2 bar so can only run 1-1.2 bar max without it going up the shitter Quote
