replaced the crank oil seal on cambelt side not so long ago to find it leaking more than the last one lol, have another one ordered aswell as the gearbox side one. just wondering is there anything else i could use to help seal it? I've the whole engine out of the car atm. i presume add a layer of oil to it before i put it in to seal it like you do with and oil filter?
Edited by starletburkie
Depends how deep it is then you would need to find out how much is acceptable then measure it. May need a polish or worse a regrind/new crank, if it's only slight though maybe new seal just needs coat of oil so it's not dry.
