td04 turbo Posted January 17, 2013 Posted January 17, 2013 Any body know if a 5e with a td05 will run on standard manegment & injectors on low boost just to run in engine before I get manegment & remap Quote
AdamB Posted January 17, 2013 Posted January 17, 2013 Yes when checked with det cans and a wideband. Quote
Azz Posted January 17, 2013 Posted January 17, 2013 Just try not too boost it at all matey it is do able, that's what I did anyway 600miles of the most depressing driving possible granny style ! Quote
td04 turbo Posted January 17, 2013 Author Posted January 17, 2013 Yea got wide band fuel pressure reg pump at ready dont like the idea of granny style lol just didn't sana go down the route of putting the ct9 on then taking it off I will add its got a external waste gate what spring pressure do u advise for first start up? Yea got wide band fuel pressure reg pump at ready dont like the idea of granny style lol just didn't wana go down the route of putting the ct9 on then taking it off I will add its got a external waste gate what spring pressure do u advise for first start up? Quote
AdamB Posted January 17, 2013 Posted January 17, 2013 Use stock boost pressure 0.6 bar and retard the ignition timing to 6 BTDC, since its a larger engine you will have to increase fuel pressure, as well as accomodate the extra flow of the turbo. Quote
td04 turbo Posted January 17, 2013 Author Posted January 17, 2013 Thank god for this form nice one td05 20g it is Quote
AdamB Posted January 17, 2013 Posted January 17, 2013 20g? Thats massive lol. What power you going for? What management you going to run? Quote
td04 turbo Posted January 17, 2013 Author Posted January 17, 2013 Not really sure to be honest its a big build just going to see what I can squeeze out of it safely as for management not sure thinking standalone at some point to fine tune it just wanna get it runing then see it defo going for a trip to tuning developments though Quote
