Cool Running Posted July 11, 2007 Posted July 11, 2007 Hi im going to be taking of my rocker cover soon to go to the polishers anybody know where i can by the Gasket for the cover ??Cheers Quote
gaz Posted July 11, 2007 Posted July 11, 2007 Toyota about 7 or 8 quid i think i recall.I dont think Toby does them Quote
Glanza_Ragger Posted July 11, 2007 Posted July 11, 2007 You can normally reuse the rocker cover gaskets, as long as there not damaged, just put a bead of silicone around it to help seal. Quote
Cool Running Posted July 11, 2007 Author Posted July 11, 2007 You can normally reuse the rocker cover gaskets, as long as there not damaged, just put a bead of silicone around it to help seal.Yeah i going to try and reuse it.. Just like to know that i can buy a gasket if i need to Cheers Quote
Jozinobi Posted July 11, 2007 Posted July 11, 2007 Part numbero : 11213-11041Pricereno : £8.11 plus VATOld one can be reused but inspect it for leaks after a few 100 miles once refitted.Sweet Jesus, just noticed the amount of porn links on this site tonight. Looks like we've been violated - haven't seen that amount of filth since Ecksjay left! Its an automated bot we think, that has infiltrated the image software.We will get it sorted asap.Sorry for the inconvenience...Joz Quote
Glanza_Ragger Posted July 11, 2007 Posted July 11, 2007 Its an automated bot we think, that has infiltrated the image software.Sounds like something from the matrix Quote
Sparky Posted July 11, 2007 Posted July 11, 2007 Wouldnt be so bad if the porn links actually worked Quote
Jozinobi Posted July 11, 2007 Posted July 11, 2007 Wouldnt be so bad if the porn links actually worked *SIN BIN FOR YOU SPARKBOY*!! :P Lmao "Beware of those links, they may cause a malfunction in the UKSC Matrix, you have been warned!!"Joz Quote
